Old 5-Feb-2013, 2:10 AM   #4
Above the Peak of the roof install a Winegard HD7694P antenna aimed at about 265 degree magnetic compass direction.
http://www.ronard.com/909911.html. If using a tripod antenna mount use the 5 foot antenna mount.
http://www.ronard.com/34424560.html. If using a eave antenna mount use the #4560.
http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
The Digital Tv transmissions are strong at your location.
No preamplifier is required.
_________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
Install the HD7694P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
At your location the 2 main groups of Digital Tv transmitters are to the , south west , west , north west.
The Tv/s Must Channel Scan for the , OTA= Over The Air , Digital Broadcast Tv channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Digital Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
______________________________________________
If keeping any type or kind of pay cable service such as , cable tv service , cable internet service , cable phone service.
The Tv antenna and the cable delivered service cannot be on the same coax.
As an example , the cable internet service must be on a separate coax.
Yes the coaxes that are in or on the house can be used for the antenna system.
