Old 4-Feb-2013, 9:57 PM   #9
I'd really like to assure you that you have a very simple, straight forward... easy situation. You don't need to go big to get good results. So long as you are not blocked by dense trees or neighboring buildings, the 7000 is plenty. If you want to over-build, the 7015 will work well on a guyed J-pole.
I see no reason to consider a preamp or distribution amplifier. The signal power in the air would likely overload an amplifier which would interfere with reliable reception.
