The 7694 is a great option, and in your case you would easily drive a 4-way splitter or even an 8-way. The only downside to the 7694 is that it lacks support for real channel 2 through 6. There are a couple of signals listed, though I may not be interested in the content currently broadcast, that could change 'with the stoke of a pen'.
The 7698 would also provide reliable reception, but even though I lean toward over-built recommendations, the 7698 seems much larger than needed in your case. (It too, lacks support for CH-2 through 6)
I'm still quite confident the smaller HD7000 is going to be able to drive a 4-way splitter. But the next steps up, the 7010 & 7015 add yet more signal to spare.
If you keep the antenna size reasonable, the 3' J-pole will do very well, especially with the guy-wires installed.
Reason: sp.
