If you opt to start with just the UHF only antenna (DB4e) you likely don't get to see WBKO reliably. As I go down the list, the other ABC affiliates are also broadcasting on VHF channels. For our household, no ABC would be unacceptable. I would start with the DB4e, UVSJ, YA1713 (or Antennacraft Y10713) and preamp. Though you could opt for the HD769X and preamp to start.
The 40" J-pole is OK, but the higher you mount, the better. Reliable reception primarily depends on the selection of the antenna and it's location. Amplifiers and other accessories can't fix reception problems caused by poor antenna location.
