Tv Reception
The transmitters are local. If address is correct , you are in a bad spot. Do this , go to the >Start MAPS< part of tvfool. Put in your address , Zoom down and raise the antenna height , also move the antenna location ( the red balloon pointer) around on your property. You are looking for better signal , hot spots. It looks like K51DW 51 translator is NBC , and DKBTZ 24 translator is PBS. If you will provide the addresses of the houses or the Full latitudes and longitudes of the houses , We can be of more help.
