If you have been satisfied with the performance and reliability of the reception provided to one and two sets, keep the existing antenna as is and add a Channel Master CM-3410 distribution amplifier between the antenna and splitter. Or, use either the CM-3414 or CM-3418. These have built in splitters. All are based on the same 15 dB amplifier.
