Old 4-Feb-2013, 7:48 AM   #3
tomin
teleview,
the report is:
http://www.tvfool.com/?option=com_wr...1dda77081d0fdc
When you said "Make the antenna height 25 feet", I assume that is what you wanted for report purposes---so that is what I used in creating the report. The actual antenna is about 6 feet off the floor. This is as high as I can place the SS3000 antenna in its current closet location. (The closet is only about 22" deep and the antenna needs to stick out the open door.) Moving an antenna to my attic is not a do-it-yourself option because I'm not in the physical condition to walk/crawl around the unfloored ceiling joists in the attic.
tomin is offline   Reply With Quote
