Thread: OTA in Rural KY
Old 4-Feb-2013, 6:51 AM   #3
Antenna System #1.
For reception of the , Louisville / Lexington , area Digital Tv stations/channels.
Above the Peak Of The Roof.
Install a Antennas direct DB4e UHF antenna aimed at about 65 degree magnetic compass direction.
And on the same antenna mast , below the DB4e , install a Winegard YA1713 VHF antenna aimed at about 45 degree magnetic compass direction.
Connect the DB4e and YA1713 antennas together with a UVSJ = UHF/VHF Separator/Joiner.
The DB4e is connected to the UHF connection of the UVSJ.
The YA1713 is connected to the VHF connection of the UVSJ.
Type the letters uvsj in the , http://www.solidsignal.com , search box.
The remaining connection of the UVSJ is connected to a Winegard HDP-269 preamp.
__________
For 1 Tv connection use No splitter.
For 3 Tv's connected use a , HFS-2D , 3 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com , http://www.hollandelectronmics.com.
______________________________________________________________________________
http://www.ronard.com/909911.html , if using a tripod antenna mount use the 5 foot antenna mount.
http://www.ronard.com/34424560.html , if using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
I strongly recommend use the Correct splitter that has the correct number of outputs to the Tv locations.
Example , if 2 Tv locations are to be connected then use a 2 way splitter.
Example , if 3 Tv locations are to be connected then use a 3 way splitter.
Here is a easy way to to use Digital Broadcast Tv tuners and DVR's.
http://www.epvision.com.
http://www.channelmasterstore.com.
________________________________________________________________________________ _
Antenna system #2.
Is a SEPARATE Antenna System and is not connected to antenna system #1.
Install a Winegard HD7696P antenna with a Winegard HDP-269 preamp.
_________
The HD7696P antenna can be aimed by hand at the Evansville group of Digital Broadcast Tv stations/channels at about 285 degree magnetic compass direction , or , Bowling Green group of Digital Broadcast Tv stations/channels at about 186 degree magnetic compass direction.
The HD7696P antenna can be turned by hand to Test receive the 2 groups of Digital Tv stations/channels to find the group you will like to receive all the time.
Or can put the HD7696P antenna on a separate antenna mount and install a Channel Master CM9521A antenna rotator.
Or in place of the HD7696P antenna and HDP-269 preamp.
Can install a , Winegard 2002 Metro Star , Or a Channel Master CM3000A , Omni directional antenna for reception of Evansville / Bowling Green , and what is received is what is received.
Antenna systems #1 and #2.
Are Not connected together on to one coax.
Antenna systems 1 and 2 are Separate antenna systems All the way to the Tv locations.
At each Tv location a Remote control A/B antenna switch will be connected to the Separate antenna systems.
http://www.mcmelectronics.com , #32-4425.
A/B antenna switching is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.
Here are some places to buy antennas and etc..
http://www.solidsignal.com.
http://www.amazon.com.
http://www.hollandelectronics.com.
http://www.mcmelectronics.com.
