Old 4-Feb-2013, 2:12 AM   #4
For Reception of.
CFPL-DT VHF Digital Channel 10 , CTV TWO.
CJMT-DT UHF Digital Channel 20 , OMNI 2.
CICO-DT UHF Digital Channel 18 , TVO.
CITS-DT UHF Digital Channel 14 , Religion.
CFMT-DT UHF Digital Channel 48 , OMNI 1.
CHCH-DT UHF Digital Channel 51 , IND.
CITY-DT UHF Digital Channel 31 , CITY TV.
CKCO-DT VHF Digital Channel 13 , CTV ONE.
CIII-DT VHF Digital Channel 06 , GTN.
CIII-DT UHF Digital Channel 17 , GTN.
Above the Peak Of The Roof so that reception is not blocked in all directions by the roof or house.
Install a Winegard HD7082P antenna aimed at about 42 degree magnetic compass direction.
______________________________________
(((I found No CBC Digital or Analog Tv stations for , St-Thomas , London , or surrounding area.)))
Also install a Winegard HDP-269 preamp.
Here are places to buy , Antennas , HFS splitters , and etc. , [URL="http://www.saveandreplay.com"]http://www.saveandreplay.com[/URL , http://www.trentondistributors.com] , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.hollandelectronics.com.
_________________________________________
Some Above the Roof antenna mounts are , Tripod antenna mounts , Eave antenna mounts , Chimney antenna mounts.
_____________________________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' because the OTA= Over The Air Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
