Old 3-Feb-2013, 10:30 PM   #3
The ANT-751 would work, but not do as well with the weaker signals. As you go down the list in your TVFR, I would expect you to have trouble with some of the edge path signals in the yellow section.
I would opt for the larger antenna that teleview has suggested. It will give you more signal strength making reception more reliable and give you a better chance at the weaker signals.
