Old 3-Feb-2013, 7:30 PM   #2
A Simple reception situation.
For Reliable Reception.
Above the Peak Of The Roof in such a manner that roof and house are not blocking reception to the , south east , groups , of Digital Tv stations/channels.
Install a Winegard HD7696P antenna aimed at about 120 degree magnetic compass direction.
Here are some antenna mounts.
http://www.ronard.com/909911.html , if using a tripod antenna mount use the 5 foot antenna mount.
http://www.ronard.com/34424560.html. If using the eave antenna mount use the #4560.
http://www.ronard.com.
___________________________________
Use No preamplifier.
__
____________________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own house and roof.
It is best to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the OTA = Over The Air Digital Broadcast Tv channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the OTA channels travel Over The Air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
