Old 3-Feb-2013, 3:28 PM   #2
Attics Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Install the ANT751 , VHF channels 7 thru 13 , UHF channels 14 thru 51 antenna in the attic aimed at about 48 degree magnetic compass direction.
The ANT751 has some forward antenna signal gain and also receives at the front angles , back angles , back of the antenna.
The ANT751 should also receive KTWU UHF Digital channel 36 PBS that will be at a back angle to the ANT751 antenna.
The DB4e with its reflector screen will most likely in combination with being in the attic , block reception of KTWU , and the DB4e is a UHF channels 14 thru 51 design antenna.
And also I am recommending the ANT751 because the Digital Tv stations/channels to the , north west are currently in the UHF channels 14 thru 51.
And.
That is likely to change in the near future , as the UHF channel band at your area becomes more crowded.
Then Digital Tv stations will go to the VHF channel band 7 thru 13.
________________
The ANT751 comes with a , J pole type antenna mount.
http://www.solidsignal.com , http://www.amazon.com.
