Old 18-Oct-2010, 9:12 PM   #34
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
Another antenna is likely to screw up what you already have: I believe that a rotator would cost only a little more than another antenna, and would work a whole lot better. You might also consider using a high-input preamp like a Winegard HDP-269, which MIGHT give you the little extra signal that you need to get WSBE reliably, but a rotator is likely to do it better...
