Old 2-Feb-2013, 11:45 PM   #4
With the HD7000R aimed as directed , the Current Plus Pending Applications Included Digital Tv stations/channels down the list to and including WLVT-DT UHF Digital channel 39 PBS , in the Green and Yellow reception zones will be received.
____________________________________________________________
If you will like to reach out for more Digital Tv stations/channels , on down the stations/channels list past WLVT.
Then do not install the HD7000R antenna system.
Install a Winegard HD7084P antenna aimed at about 160 degree magnetic compass direction.
Install a Winegard HDP-269 preamp.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Because the weaker signal strength WLVT-DT UHF Digital channel 39 PBS , will be at a back angle to the HD7084P antenna.
Will most likely need to adjust the back angle aim of the HD7084P antenna for best reception at a back angle to the antenna.
The HD7084P antenna is a big directional antenna in the forward direction and as such receives very good at the front of the antenna but less at the back angles and back of the antenna then the HD7000R that receives more at back angles and back of the antenna.
_________
Most Digital Tv's have a Signal strength meter and some Digital Tv's also have a Signal Quality meter.
