Old 30-Jan-2013, 8:04 PM   #4
chiefgeek
Originally Posted by No static at all View Post
Do you have the switch inside the 7777 set to combine? Is the FM trap set to IN? If these suggestions do not solve your problem, you would be better served with a distribution amp rather than a pre-amp. I recommend the Channel Master 3418 for your needs.
Combine yes
FM Trap IN
I tried putting FM Trap to OUT and I get some signal on wfaa 8.1 (vhf 8) but not enough to be useful.
Thanks for the recommendation, I will give it a try.
chiefgeek is offline   Reply With Quote
