Old 30-Jan-2013, 6:26 AM   #3
To go down the Digital channel list and reach out for , http://en.wikipedia.org/wiki/WBBZ-TV.
Install a Winegard HD7084P antenna with a Winegard HDP-269 preamp aimed at about 170 degree magnetic compass direction.
Buy the HFS splitters at , http://www.solidsignal.com , http://www.amazon.com , http://www.saveandreplay.com , http://www.trentondistributors.com.
The correct way to connect Tv's is to use the splitter that has the correct number of outputs to the Tv's.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
And so forth.
_________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Broadcast Tv reception , and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7084P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
