Old 29-Jan-2013, 2:01 AM   #3
A Simple reception situation.
The Tv stations to the , north east , are infomercials and languages other the english.
The Tv stations at 177 degree magnetic compass direction are Strong Signal Strength , LOS = Line Of Sight , 7.2 and 7.3 miles away , so no requirement to aim a antenna directly at the Tv stations.
That leaves the Tv stations to the south east.
The spread of the Tv stations to the south east is 25 degrees.
This is Well Within the Reception Ability of 1 Tv Antenna.
And the Tv stations at 177 degree magnetic compass direction are So Strong that the Tv stations will be received no matter what direction a antenna is turned.
Above the peak of the roof install a Winegard HD7696P antenna with a Winegard HDP-269 preamp , aimed at about 137 degree magnetic compass direction , a in between aim direction.
________________________________________________
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Here are places to buy the HFS splitters.
http://www.solidsignal.com or http://www.hollandelectronics.com.
_________________________________________________
______________
http://www.ronard.com/909911.html if using the tripod antenna mount use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html if using a eave antenna mount use the #4560.
http://www.ronard.com.
______________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , reception and so do buildings and other obstructions including your own roof and house.
It is best install the HD7696P antenna at a location that has the ;least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
