Old 28-Jan-2013, 8:57 AM   #3
A Simple reception situation.
Above the roof in such a manner that the roof and house are not blocking reception in all directions install a Winegard HD7696P antenna with a Winegard HDP-269 preamp aimed at about 70 degree magnetic compass direction.
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Here are places to buy HFS splitters.
http://www.solidsignal.com or http://www.hollandelectronics.com.
___________
As a Test of reception , aim the HD7696P antenna at about 277 degree magnetic compass direction.
For reception of the Digital Tv stations/channels to the west.
If reception is good with the Tv stations/channels to the west and you will like to continue to receive them.
Turn the antenna back to about 70 degree magnetic compass direction.
Install a second HD7696P / HDP-269 / splitter / coax system.
The 2 antennas systems will not be connected on to one coax.
The 2 Separate antenna systems will be Separate all the way to the locations of the Tv's , and a Remote control A/B antenna switch will be connected at each Tv location.
Remote control A/B antenna switching is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and Keep On Channel Surfing.
_________
Putting 1 Tv on a antenna rotator Is Not channel surfing friendly , must wait for antenna to rotate and there Will Be Domestic Situations about the direction the antenna is aimed.
___________________
http://www.ronard.com/909911.html if using a tripod antenna mount use the 5 foot antenna mount.
http://www.ronard.com/34424560.html if using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
_________________________
If mounting 2 antennas on one mast , separate the antennas by about 3 feet.
