Old 28-Jan-2013, 8:11 AM   #2
Aim a Antennas Direct Clear Stream 2 V Complete UHF/VHF antenna at about 185 degree magnetic compass direction.
http://www.antennasdirect.com/store/...VHF-Combo.html.
For 1 Tv connected use No splitter. No amplifier.
For 2 Tv's connected use a simple common 2 way splitter. No amplifier.
Looking at the tvfool Current Plus Pending Applications Included Digital channel list.
The Digital Tv stations/channels down to and including.
CITY-DT UHF channel 31 , CITY TV , should be received with 2 Tv's connected.
If not , then install a Channel Master CM3410 distribution amplifier before the splitter.
____________________
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.channelmasterstore.com
______________________
If you will like to Experiment with reception of the USA Digital Tv stations.
Then aim the CS2v Complete at about 130 degree magnetic compass direction.
WNLO-DT REAL UHF Digital channel 32 , virtual number (23.1) The CW.
WNYB-DT REAL UHF Digital channel 26 , virtual number (26.1) IND.
WIVB-DT REAL UHF Digital channel 39 , virtual number (4.1) CBS.
WNED-DT REAL UHF Digital channel 43 , virtual number (17.1) PBS.
WKBW-DT REAL UHF Digital channel 38 , virtual number (7.1) ABC.
The CM3410 distribution amplifier might help with reception of the USA Digital Tv stations/channels.
Most likely , the same Canada Digital Tv stations/channels will be received with antenna aimed at 130 degree as with the antenna aimed at 185 degree.
And perhaps with the CS2v Complete antenna aimed at about 130 degree or so , might even pick up the CBC Digital Tv station/channel , CBLT-DT UHF channel 20 , at 85 degree magnetic compass direction.
The antenna aiming is Experimental to find the best reception.
Most Digital Tv's have a signal strength meter , and some digital tv's have a signal quality meter.
The Tv's Must Channel Scan for the Digital Broadcast Tv channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
_________________
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
It can help to Double Channel scan.
Last edited by teleview; 29-Jan-2013 at 2:30 AM. Reason: I have corrected the typo from CM3212 to CM3410.
