Thread: Help Antenna
Old 28-Jan-2013, 5:14 AM   #3
http://www.fcc.gov/mb/facts/otard.html.
The Federal Antenna Law is for you so you can install a antenna above your roof that can be seen from the road.
The Onus is on the HOA , and they must pay your legal fees and their legal fees should they choose to pursue the matter.
The Federal Antenna Law is Settled law.
HOA's have Lost , time after time in court.
Beyond the legal issues , there are , Evil , Sick and Twisted people that Hate antennas of all types and kinds.
They hide behind rules and regulations to push their Evil off on to others.
______________________
Yours is a Simple reception situation.
Above the roof in such a manner that the Tv antenna will be above the high point of the roof.
Install a Winegard HD7696P antenna with no amplifier aimed at about 185 degree magnetic compass direction.
http://www.ronard.com/909911.html if using the tripod antenna mount use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html if using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
For 1 Tv connected use No splitter. No amplifier.
For 2 Tv's connected use a simple common 2 way splitter. No amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
To avoid hassles with connections to the satellite Tv system.
Remove All satellite Tv hardware such as , multi-switches , diplexers , splitters , power supplies , power injectors , amplifiers, and etc..
And use the satellite system coaxes and other coaxes that are in or on the house for the broadcast Tv antenna system.
Or contact your satellite system installer to see if a broadcast Tv antenna can be connected to the satellite system. Some satellite systems will transfer the broadcast Tv antenna channels through the system and some satellite systems will not , there are many variables , it is not a simple issue.
Even so , to avoid reception problems that will happen with a broadcast Tv antenna connected in the satellite system.
I recommend cancel satellite system subscription and remove All of the satellite system hardware.
And use the satellite system coaxes and coaxes that are in or on the house for the Broadcast Tv antenna system.
Or can install a Separate coax system for the broadcast Tv antenna system.
__________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in all directions including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Digital Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Digital Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
