Old 28-Jan-2013, 4:02 AM   #5
Is this a , house , town home , condo , apartment , mobile home , motor home , or etc. ??
____________________
Attics are not a reception friendly environment because of the attenuation and signal reflections , multipath.
In the attic install a Winegard YA1713 antenna with a Antennas Direct CPA-19 preamp.
Aimed at about 165 degree magnetic compass direction.
For 1 tv connected use No splitter.
For to Tv's connected use a , HFS-2D , 2 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
________________________________________________________________
Here is another way.
If there are any of those small satellite dishes (dish network or direct tv or FTA dishes) on the Outside of the building.
Then.
Here is a Broadcast Tv Antenna that is made to look like a (small dish) on purpose.
The http://www.antennacraft.net , http://www.antennacraft.net/pdfs/HDX1000.pdf , http://www.antennacraft.net/Manuals/HDX1000_manual.pdf.
-->Do Not<--> put the HDX1000 in the attic.
The reason is the HDX1000 will not receive any better then the CM3010 in the attic.
The point and purpose of the HDX1000 is to be on the Outside of the building for reception because it looks like a small satellite dish.
Install the HDX1000 UP HIGH on the Outside of the building.
So the HDX1000 clears the high point of the roof in the directions of , north and south / south west.
Aim the HDX1000 at about 165 degree magnetic compass direction.
Your location has Tv stations to the south / south west.
KBDI-TV REAL VHF Digital channel 13 , virtual number (12.1-2-3) PBS.
KMGH-TV REAL VHF Digital channel 7 , virtual number (7.1-2-3-4) ABC and Azteca America and Cool Tv and 24/7 News.
KUSA-DT REAL VHF Digital channel 09 , virtual number (9.1) NBC and AccuWeather.
__________
And to the north.
KQCK REAL VHF Digital channel 11 , virtual number (33.1) MundoFox.
And it is a real stretch that ,
KZDE-LD REAL UHF Digital channel 14 , virtual number (x.1) Religion. Might be received.
KFCT-DT REAL UHF Digital channel 21 , virtual number (22.1-2) FOX and Antenna Tv , might be received.
As always , trees and tree leaves do a real good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and building.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including the roof and building the antenna is installed in on.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmission travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , Digital , 'Air Channels / 'Antenna Channels'.
