Old 27-Jan-2013, 9:47 PM   #2
Consider the high gain and wide forward beam of the Antennas Direct DB-4e. Pair that with a High-VHF antenna such as an Antennacraft Y5713. You can then optimize the UHF aim and VHF independently. Combine the two using a UVSJ.
Outdoor mounting would be ideal. In the attic is an unknown until you put an antenna up there to see what the roof construction does in your case.
