Originally Posted by h20rat
Q: Is the CM-7777 more suited for a single TV configuration?
No. The CM 7777 is a good pre-amp with high gain. It's output levels should be strong enough to drive multiple TV with no problem.
would I be better served with something like a Winegard AP-8275?
The Winegard 8275 performance is in the same ballpark as the Channel Master 7777, so either one would work.
My goal is to get a good configuration with the least possible drop-outs, pixelization etc., since this will be our primary access (no more cable fees..yay!)
Then, by all means, go up one antenna size for the extra reliability.
