Old 27-Jan-2013, 8:49 PM   #1
jnothwang
New to OTA - Help in Boulder, CO (Denver stations)
I am new to OTA and just installed my antenna yesterday.
Channel Master CM3010: http://www.channelmasterstore.com/Di..._p/cm-3010.htm
It's in the attic, aimed at the Denver stations, but unfortunately I only get one major network (NBC - channel 9) and that only sporadically.
Any ideas as to how I pick up CBS and ABC in addition to NBC? I have not yet installed a signal amplifier - currently the antenna is running on RG-6 from the attic to a junction box, then throughout the house using existing in-wall cabling. It's a long run with a few splices so that may be the issue, but before installing amps for each TV (or getting a different antenna) I want to make sure I can get the three networks in the first place (or may have to go back to Comcast!).
TV Fool report is at http://www.tvfool.com/?option=com_wr...1dda869fd07abd
Any guidance on next steps, including recommendations on a different antenna (that will fit in the attic) - this one was recommended by the folks at Crutchfield - is appreciated!
Josh
jnothwang is offline   Reply With Quote
