Old 26-Jan-2013, 9:57 PM   #19
dplav
Originally Posted by elmo View Post
It's a UHF design only so it won't pick up your available VHF channels. And it's nothing magical. They call it omni-directional because there's no reflector, but it's reception will vary based on direction it faces. If you have a broadcast tower nearby, it doesn't require much antenna to pick it up well. For 35 miles, it has to be an optimal situation; I doubt they disclose that test scenario. It could work for you, but just be ready to return it. Slick marketing. I like the part about "designed after a military mudflap antenna." I guess the military likes to watch TV while out and about?! Not hardly. It's like saying a Toyota Camry is based on race car design because it has cylinders and gears too. Who knows what a military mud flap design is used for. I could be for near field communications on a specific frequency, which would not be optimal for a TV application. So like I said, if you are inclined to try it, be aware of the return policy. If you're a bit crafty, there's always the "build your own moho" for just a couple of bucks. http://www.instructables.com/id/Yet-...dtvsecretscom/
Yeah - it's virtually the same thing - same design, for sure. I can say I actually did this little project the first time I started looking into antennas. It took little time to assemble and I attached it to the back of the TV. It did ok, but nothing like the outdoor antenna I eventually got. But it was fun to do.
As for the expense of getting an antenna installed, when you cut the cord, you can afford to spend a little as the savings will pile up in the long run.
Here's what I tried without having much luck watching locals on a cloudy day. It was choppy.
http://m.bestbuy.com/m/e/product/det...=1171058630563
If I didn't have luck with this should I even try the Leaf?
dplav is offline   Reply With Quote
