Old 26-Jan-2013, 2:57 PM   #5
No respond.
Well any way.
Based on the tvfool report at the city level.
Install a Winegard HD7000R antenna above the Peak of the roof aimed at about 90 degree magnetic compass direction.
Install a Winegard HDP-269 preamp.
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
______________________________
For the reception of.
K20DT REAL UHF Digital channel 38 , virtual number (20.1) has CP construction permit.
K15BP-D REAL UHF Digital channel 15 is a repeater station of , KDRV-DT REAL VHF Digital channel (12.1) ABC.
K44JB-D REAL UHF Digital channel 44 is a repeater station of , KMUV-DT FOX and Me-Tv.
K49JE-D REAL UHF Digital channel 49 is repeater station of , KOBI channel 5 NBC and Weather.
KBLN-DT REAL UHF Digital channel 30 , virtual number (30.1) Religion.
K04EY REAL VHF Digital channel 04 , has a CP construction permit to be a repeater of KOBI NBC.
K19HS-D REAL UHF Digital channel 19 is a repeater station of , KSYS-DT channel 08 PBS.
K22FC REAL UHF Digital channel 22 , virtual number (22.1) Religion.
K47GI REAL UHF Digital channel 47 , virtual number (47.1) Religion.
K02JJ-D REAL VHF Digital channel 02 is a repeater station of , KSYS-DT channel 08 PBS.
K04JZ REAL VHF Digital channel 04 is a repeater station of , KTVL VHF channel 10 CBS and CW.
http://www.ronard.com/909911.html if using the tripod antenna mount use the 5 foot mount.
http://www.ronard.com/34424560.html if using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal buy typing the word ronard in the solidsignal search box or buy from ronard.
_______
Can also use a Winegard DS3000 , J type antenna mount.
_______
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
_______________
As always , trees and tree leaves do a real good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstructions of reception including your own roof and house.
The directions of reception are , north east , east , south east.
