Old 26-Jan-2013, 8:12 AM   #4
Your current reception location is between a Rock and a Hard Place.
_______________________________________________________
In the Current Plus Pending Applications Included Digital tvfool radar plot report and channel list , CBUT-DT REAL UHF Digital channel 43 , virtual number (2.1) CBC , is listed.
The tvfool report shows the , Real channels , and , (Virt) virtual numbers.
All receivable Digital Tv stations/channels are UHF channels at your current location.
The current UHF Tv channels are , 14 thru 51.
_____________________________________________________________
Try this.
For reception of the Canada Digital Broadcast Tv stations.
Put a Antennas Direct , Clear Stream 2 UHF antenna , in the 5 foot tall by 1 foot wide bedroom window.
Tipping / aiming , the antenna up in the window , might help with reception.
It is experimental aiming to find the best reception.
The Canada Digital Tv transmissions to the , north east , are strong signal strength , so do not use a signal amplifier.
Use a loooong coax to connect the antenna to the Tv.
http://www.antennasdirect.com/store/...V-antenna.html.
Try this.
For reception of the Canada Digital Tv stations channels to the , north east.
If there are any buildings or something to get a reflected Tv signal to the , south west , west.
Put the CS2 UHF antenna in the living room window or out on the patio/porch , and aim the CS2 UHF antenna , toward the buildings if there are any , might be able to get some useable signal reflections , tilting the antenna up might help with reception.
It is experimental aiming to find the best Tv signals.
Use a loooong coax from the antenna to the Tv.
The Canada Digital Tv transmissions to the , north east are strong signal strength so do not use a signal amplifier.
If you find a good , antenna aim/adjusted direction , with simple channel scans.
Then can help to do Double Channel Scan.
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
http://www.dtv.gov/rescan.html.
______________
Here is how to aim antennas.
Here are some places to buy antennas and etc. ,
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.solidsignal.com.
http://www.amazon.com.
As a Test of reception for the USA Digital Tv stations/channels.
Try aiming the CS2 UHF antenna the best you can , to a south east / south direction.
A Double channel scan can help with reception.
If some USA Digital Broadcast Tv channels are receivable.
Then I recommend a 2 antenna setup , 1 CS2 antenna for the Canada Digital Tv stations and 2nd. CS2 antenna for the USA Digital Tv stations/channels.
For reception of the USA Digital Tv stations channels a Antennas Direct CPA-19 preamplifier might help with reception.
DO NOT use the CPA-19 preamp for reception of the Canada Digital Tv stations/channels.
If using 2 Separate CS2 antennas , Do Not connect the 2 antennas on to 1 coax.
The 2 Separate antenna systems are Separate all the way to the Tv/s locations.
If 1 Tv is connected use No splitter.
If 2 Tv's are connected use a HFS-2D , 2 way splitter.
If 3 Tv's are connected use a , HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com , http://www.hollandelectronics.com , or , http://www.hollandelectronics.com , http://www.saveandreplay.com . http://www.trentondistributors.com
A remote control A/B antenna switch will be used to change antennas , Canada and USA antennas , and Keep on Channel Surfing.
Saveandreplay has the remote control A/B antenna switch.
Moving to a top floor / 4th floor apartment will help with reception to have reliable reception and most likely more Tv stations and channels.
Select a apartment higher up that has good views to the , north east , south - south east , at a minimum.
And a apartment with good views in all directions will also help with reception.
