Old 25-Jan-2013, 6:09 PM   #1
eenvon
Cutting comcast, looking for good antenna options
http://www.tvfool.com/?option=com_wr...1dda2a577a7392
I'm cutting the cord and looking for a good option for OTA. I'm not far from the broadcasting towers but I'm curious if I could get greedy and try to pull more channels. The antenna will be in the attic of a 2 story so figured about 30' high. I would put it on the outside but covenants and restrictions prevent that. I'll probably hook up 3 to 4 tvs to it with vary run lengths. The longest run would be about 50'. If you guys could provide some suggestions on the correct antenna and if a pre-amp would even be needed it would be greatly appreciated. Thanks in advance.
eenvon is offline   Reply With Quote
