Old 25-Jan-2013, 5:28 PM   #3
No static at all
No static at all's Avatar
You would better served with separate UHF/VHF antennas for best performance; especially for UHF. I recommend the Antennas Direct 91-XG / Antennacraft Y10-7-13 for maximum signal pulling power. Both antennas are lightweight & will have less wind loading issues than your present antenna.
Combine the 2 antennas with the Antennacraft 10G222 dual input pre-amp for minimal signal loss. The antennas need at least 1 foot of vertical separation on the mast to avoid signa interaction between them.
