Old 24-Jan-2013, 11:05 PM   #12
The ClearStrem 2 is a UHF only design. That should cover the signal from WPXN on real CH-31. However, as I mentioned earlier, the buildings around you can make reception more difficult than your TV Fool prediction would suggest.
The rabbit ear type antenna typically has elements for both UHF and VHF... so it's not a surprise that that antenna does a better job with real channels 2 through 13.
My earlier suggestions still stand, including the option of a more directional antenna, preferably mounted outside in the clear. Consider the Winegard HD7000R, HD7010 and HD7015 as well as comparable models from other manufactures such as Channel Master and Antennacraft. (ex. CM-3016 & C290)
