Old 24-Jan-2013, 4:00 PM   #2
Your location has receivable Digital Broadcast Tv stations/channels in All 3 Broadcast Tv channel bands.
UHF band channels 14 thru 51.
Above the -->Peak<-- of the roof install a Winegard HD7000R All Channel antenna in such a manner the roof and house are not blocking reception to the , north west and south.
Aim the HD7000R antenna at about 305 degree magnetic compass direction.
For 1 Tv connected use No splitter. No amplifier.
For 2 Tv's connected use a simple common 2 way splitter. No amplifier.
For 3 Tv's connected use a simple common 3 way splitter. No amplifier.
Here are some above the roof antenna mounts ,
http://www.ronard.com/909911.html , if using a tripod antenna mount use the 5 foot antenna mount.
http://www.ronard.com/34424560.html , if using the eave antenna mount use the #4560 mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
________________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstructions of any type or in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna CHannels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , Digital , 'Air Channels' / 'Antenna Channels.
Last edited by teleview; 26-Jan-2013 at 5:48 AM. Reason: Correct typo's and clairify information.
