Thread: Baaad Reception
Old 23-Jan-2013, 4:12 AM   #2
Above the roof in such a manner that the roof and house do not block reception to the , south west and south , install a Winegard HD7698P antenna with a Winegard HDP-269 preamp aimed at about 215 degree magnetic compass direction.
http://www.ronard.com/909911.html if using tripod antenna mount use a 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html if uaing a eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
________________________________________
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
As always , trees and tree leaves do a real good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions including your own roof and house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , Digital , 'Air Channels' / 'Antenna Channels'.
