Old 22-Jan-2013, 2:20 PM   #2
As always , the Boohoo Leaf , is a B-A and D antenna.
_____________
Indoors Is Not a reception friendly environment and Never Will Be a reception friendly environment.
Tv signal attenuation and Tv signal multipath - Tv signals bouncing all around.
___________
As a short term solution that receives the first five Digital Tv stations/channels of the tvfool Current Plus Pending Applications Included channel list , the Tv stations in the Green reception zone.
Install a TERK HDTVi ( not HDTVa) antenna on the first floor.
In/at a window that is toward the , north east , is better for reception.
Aim the HDTVi at about , 58 degree magnetic compass direction , here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Basements are Not Good for reception with a Tv antenna in the basement.
Run a loooong coax from a antenna that is above ground to the Tv in the basement.
The Digital Tv stations channels that are in the Red reception zone will not be received with the - Short term solution HDTVi antenna.
_______________________________________________________
Attics Are Not a reception friendly environment and Never Will Be a reception friendly Environment.
Tv signal attenuation and Tv signals bouncing all around - multipath.
________________
Here are the Digital Tv channels in the Red reception zone.
W16CO-D REAL UHF Digital channel 16 , virtual number (x.1) Religion.
WSBW-DT REAL UHF Digital channel 31 , virtual number (38.1-2) CW and Me-Tv.
WBPH-TV REAL VHF Digital channel 09 , virtual number (60.1) Religion.
WQPX-DT REAL UHF Digital channel 32 , virtual number (64.1-2-3) ION and QUBO and ION Life.
W43CO-D REAL UHF Digital channel 43 , virtual number (x.1) Religion.
Start with the HD7082P antenna in the attic and then move to above the roof for better reception.
Aim the HD7082P antenna at about 40 degree magnetic compass direction.
As always , trees and tree leaves do a real good job of , reflecting , reducing , blocking , Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7082P antenna above the roof in such a manner that there is little obstructions to no obstructions of any type or kind in the directions of reception including your own roof and house.
The Tvs Must Channel Scan for the , Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Some Digital tv's will automatic channel scan for cable tv channels.
Go into the Tv setup menu and select , 'Air Channels / 'Antenna Channels'.
