Old 21-Jan-2013, 11:02 PM   #15
Harrier
How old is that Sharp? Have you check its specifications to ensure it has an ATSC tuner, then followed its specific setup instructions for use with an antenna? The Aquos product has been out for over ten years.
Sharp is from 2007 or 8, so it is not new. But is is a LC42D62U and has an integrated ATSC/QAM/NTSC tuner. I used the channel search function specifying over the air (not cable). It runs the 70-channel sweep, but finds nothing. I tried resetting by unplugging the cable and running channel scan, then plugging it in and running channel scan again. At one point, I got one channel, so I suspect the tuner is not blown.
If you are re-using in-place cable from the satellite service, have you removed any multi-switches or the like that were needed for the satellite service?
I am using the feed cable from the satellite because it is there, but it connects in the wiring closet to a standard splitter and then to the two TV locations. No satellite gear inline.
Harrier is offline   Reply With Quote
