Old 18-Oct-2010, 3:01 PM   #32
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
The issue is that, while WSBE is closer to you than the Boston signals, it is MUCH weaker than just about all of them, and your antenna is aimed at Boston. Question for you: can you see WHDH, the Boston NBC station clearly with your antenna aimed where it is? If you can, WSBE is really an aiming issue. While I am sure that WSBE will improve if you move the antenna towards the Providence transmitters, you will lose the some of the Boston stations if you do so. Since you have 2 very good PBS stations in Boston that you should be able to get quite well (WGBH and WGBX) how badly do you really need and want WSBE? Installing a rotator on the antenna system would likely solve your problem, albeit at some cost and an additional trip back up to the roof. Please let us know what you decide to do...
