Old 19-Jan-2013, 1:05 AM   #6
No response for requested information.
Well any way.
For reception of what can be received with a indoor type antenna.
Most likely.
WRGB-DT PBS.
WGGB-Tv ABC and FOX and MyNetwork.
And maybe WWLP-DT NBC.
I recommend a TREK HDTVa antenna. Aimed at about 201 degree magnetic compass direction.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
The best location to put the HDTVa antenna for reception is in a , window or patio/balcony window that faces south west , south , south east.
The main group of Tv transmitters is , south and a little west , at about 201 degree magnetic compass direction.
___________________________________________________________________________
If the Tv is not close then run a loooong coax from the HDTVa antenna to the Tv.
The Tv Must Channel Scan for the Broadcast Tv Channels , often named the , 'Air Channels' or ' Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
To avoid scanning for cable tv channels , Go int the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
If you will install a Big antenna above the roof , i will provide detailed information.
