The CS2-V is a fine antenna, though in this situation, I fear it lacks the needed gain for reception of many of the weak, but available signals.
To answer your first question, "Will antenna work for me....?", Yes. A large all channel or Ch-7 through CH-51 would give you access to a good lineup of programming. Antennas such as the Winegard HD7084 or HD7698P would be in this class.
Outdoor mounting is a must if reception of the weak signals is to be successful.
