Old 18-Jan-2013, 8:10 PM   #8
rackit7
Thanks. Very good information. A few questions:
Pointing it due east won't get much in the way of reception since not much is in that direction
I am not sure why this would be pointed east, but I am new at this. Why wouldn't the antenna be pointed SW directly at the stations in NYC?
If I wanted to get the station to the NE (CT) AND SW (NY) would I be able to do it with the Winegard 7698P? I am thinking no; I would have to go with either a rotor or 2 antennas? Is that correct?
from Teleview on other posts - Remove the Reflector Screen from the CS2V antenna so the antenna will receive 2 directions , at the front of the antenna and the back of the antenna.
Would this be viable for me since my 2 primary areas are 180 degrees apart?
Thanks for the info.
rackit7 is offline   Reply With Quote
