A rotor will only work, if your tuner allows you to ADD channels.
Some tuners will only allow a complete scan, which can erase the channels detected on the first scan.
Same thing if you use an A/B switch.
You would need to combine two antennae, pointed accordingly, if a complete scan is the only scan option.
Reason: Didn't finish my statement.
