Old 17-Jan-2013, 2:15 AM   #2
Attics Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Tivo's have Ongoing Tuner Reception Issues , with Digital Broadcast Tv transmission and reception that is less then perfect.
All Digital Broadcast Tv transmission and reception is less then perfect.
___________________________________
A Simple reception situation.
For Reliable reception of the Current Plus Pending Applications Included Digital Tv stations/channels in the tvfool channel list down to and including , KLWB-DT UHF channel 50 , http://en.wikipedia.org/wiki/KLWB_(TV)
Above the roof in such a manner that the roof and house are not blocaking reception to the , south west , west , north west , north east , install a Winegard HD7696P antenna aimed at about 270 degree magnetic compass direction.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html if using the tripod antenna mount use the 5 foot tripod. , http://www.ronard.com/34424560.html if using the eave antenna mount use the #4560. , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
For 1 Tv connected use No splitter. No amplifier.
For 2 Tv's connected use a Channel Master CM 3412 distribution amplifier.
For 3 or 4 Tv's connected use a CM 3414 distribution amplifier.
As a Test to Prove Reception , Disconnect and Remove the Tivo --> Completely.
Connect the antenna system Directly to a Digital Tv and scan for Digital Broadcast Tv Channels.
Go into the Digital Tv setup menu and select , 'Air Channels' or ' Antenna Channels'.
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with a simple broadcast Tv channel scan.
Do a Double Channel broadcast Tv channel scan.
http://www.dtv.gov/rescan.html.
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
