Red herring alert. The only rivet on the "newer" C2V is not in plastic. it's aluminum on the front side of the reflector and steel on the back.
I use a 3/16" bit on a drill press to drill out the rivets when needed. Watch out, there can be sharp edges of the rivet from the drilling process.
