Antenna is now permanently mounted. After a total of approx 100 feet of cable & 10 coax couplers Following are the readings from the signal strength.
Total bars : 10
WTIC FOX: 4 bars
WFSB CBS: 1 bar
WTNH ABC: 8 bars
WCCT CW: 8 bars
WVIT NBC: 7 bars
For now, I am getting all above crystal clear HD. Should I be concerned about CBS? Unfortunately snow has stopped and I do not know how it will perform in bad weather. Should I continue to fine tune angles? What should trigger any decision to buy preamp?
More importantly, when should I declare victory over cable, open champagne & start celebrating? Is now too soon or should I wait till Superbowl just to be sure?
Thank you all for all the encouragement.
Dinesh.
