Old 16-Jan-2013, 3:17 PM   #1
Evan
Drop-outs and bad reception in Baton Rouge
Hello all.
I have just crossed the threshold into OTA antenna land. I am using a Tivo Premiere for my tuner/DVR, but I have had lots of signal problems.
I am using a Winegard FV-HD30 antenna mounted into my attic. I did not use a mast but mounted it with screws directly to a 2x4 that was facing the general direction that it needed to be pointed to receive the stations I wanted.
I was able to receive some stations, but my signal strength according to the tests that you can run on the tivo was not good, hence I had stutters and drop outs. NBC would not come in at all, which was odd to me because FOX is the same bearing on the compass and the same distance away, and it is probably my strongest channel.
I added the Winegard ANWI8700 Signal amplifier to see if that would improve my chances since I tied into the existing RG6 coax that was originally run for the cable in the attic. Probably overkill since the run was probably only about 15-20 ft until the antenna.
The antenna is very close to the roof, a few inches from it. It's a normal asphalt shingle roof with no metal around that I can see.
What am I missing? Am I doing anything wrong? Should I get a mast? Should I try a different antenna?
I know weather can be a factor and Baton Rouge has had tons of rainy and stormy weather for the last 2 weeks. So bear that in mind too.
Thanks for the help. Here is the report.
http://www.tvfool.com/?option=com_wr...1ddad80f0e245e
Evan is offline   Reply With Quote
