Old 16-Jan-2013, 2:18 PM   #9
elmo
So you've rescanned for antenna channels on the TV, right? Also ensure the least # of splitters/connections/etc. If you can, make the most direct run to the TV as possible. Each is a point of signal loss. As for the other channels, does your TV have a signal strength indicator, and if so, how do some of the others fare?
