Old 15-Jan-2013, 10:23 PM   #2
A Simple reception situation. That will receive Many Digital Broadcast Tv Channels.
Station K14MW-D has a application with the FCC - Federal Communications Commision to transmit on Digital VHF low band Channel 03.
And KTVJ-LP has a application to transmit on Digital VHF low band channel 04.
The current Tv channels are made up of 3 Tv channel bands of frequencies.
UHF band channels 14 thru 51.
So your location can have Tv channels in All 3 Tv channel bands.
More Tv stations will be transmitting on the VHF low band channels in the future.
I recommend install a , All channel , All band , antenna Now.
I recommend above the roof in such a manner that the roof and house are not blocking reception to the , north west , south east , east.
For reception of , in the Current Plus Pending Digital Channel List , the Digital Tv stations down the list to and including , KKPX-DT REAL UHF Digital channel 41 , virtual number (65.1-2-3) ION and Qubo and ION Life.
Install a Winegard HD7082P antenna aimed at about 125 degree magnetic compass direction , here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
________
Install a Winegard HDP-269 preamp.
________
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com , http://www.hollandelectronics.com.
______________________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the Broadcast Tv channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will automatic channels scan for cable tv channels.
Go into the Tv setup menu and Select , 'Air Channels' / 'Antenna Channels'.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
I recommend Remove All satellite system , multi-switches , diplexers , splitters , amplifiers , power injectors , power supplies , and etc..
And if there are any cable tv componets from the past , remove them also.
__________________________________________________
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/ychim.html , http://www.ronard.com/34424560.html if using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the soidsignal search box or buy from ronard.
http://www.solidsignal.com.
