Old 15-Jan-2013, 8:50 PM   #9
Stereocraig
Yes, I just wanted you to be aware of difference - one version of the C2V is super- easy, the other, not so much.
Should you need to reassemble the reflector, a #10 x 1 1/4" screw and nut will do the job.
Other considerations when drilling rivets, would be the drilling melting the plastic brackets and the rivet just spinning.
I always try to drill the mushroomed end of the rivet, if it's accessible.
