Old 15-Jan-2013, 3:42 PM   #8
Alternatively, if I only need to drill out a couple rivets, would the C2-V-CJM work and save $30? http://www.solidsignal.com/pview.asp...nt-(c2-v-cjm-)
Yes, I just wanted you to be aware of difference - one version of the C2V is super- easy, the other, not so much.
Should you need to reassemble the reflector, a #10 x 1 1/4" screw and nut will do the job.
