Old 14-Jan-2013, 10:54 PM   #4
Nope, you need the ClearStream 2 Complete as suggested.
There are four different SKUs for the C2V and more than that for the C2. You have to be careful what you are looking at when you look at reseller's sites.
The only version of the C2V from which you can remove the reflector without using a drill is the original version of the C2V, the C2-V-J30 which may or may not (most likely) be available from resellers. Al later versions will require the drilling out of one or two of the aluminum rivets.
