Old 13-Jan-2013, 9:21 AM   #7
Here is more information , and , going about reception a different way.
______________________________________________________
WABW will most likely Not be received reliably , Yes you can try.
I recommend Aim the HD7698P antenna with the CPA-19 preamp at about 140 degree magnetic compass direction.
For the reception of , with no rotator and without rotating the antenna.
WJHG-TV REAL VHF Digital channel 07 , virtual number (7.1-2) NBC and CW.
http://en.wikipedia.org/wiki/WJHG-TV.
WTVY REAL UHF Digital channel 36 , virtual number (4.1-2-3) CBS , MyNetwork , CW.
WMBB-DT REAL VHF Digital channel 13 , virtual number (13.1-2) ABC and This Tv.
WBIF REAL UHF Digital channel 51 , virtual number (x) DayStar.
WPGX REAL VHF Digital channel 09 , virtual number (28.1) FOX.
WDHN-DT REAL UHF Digital channel 21 , virtual number (18.1) ABC.
WECP-LD REAL UHF Digital channel 18 , virtual number (18.1-2-3) CBS and MyNetwork and Weather.
WFSU-DT REAL UHF Digital channel 32 , virtual number (11.1) PBS Florida.
(WFSG REAL UHF Digital channel 38 , virtual number (56.1) PBS is the same Florida PBS as WFSU , so no requirement to receive WFSG.)
__________________________________________________________
For this next suggestion , the HLSJ is not used and the KT200 is not used.
Your (all channel/band antenna??) could be put on the rotator and connected to a CPA-19 preamp , not the KT200 , and rotated to go after the weak signal strength Tv stations such as , WDFX-DT FOX , WJJN-LD IND. , WTLH-DT FOX , WTCW-TV NBC , WTXL-DT ABC.
_______________________________________________________________________
---->Or<---- you could be Ok with the Idea of Receiving what the HD7698P antenna and CPA-19 preamp receives , the list of Tv stations above , and leave it at that.
