Old 12-Jan-2013, 5:35 AM   #4
The 'real' antenna MUST go in the attic, ...
That may work for you... You'll need to put an antenna in there to find out if your attic is a workable location.
I would be happy just to get one each of the major networks.
Then use the largest antenna 7-51 or 7-69 combo antenna that will fit in the attic while pointing NE (62° per a compass).
Worth consideration,
Antennacraft HBU-55 or HBU-44
Channel Master CM-2020 or CM-2018
Winegard HD7698P, HD7697P, HD7696P, HD7695P or HD7694P (Noted as being difficult to re-fold if they need to be moved out of the attic.)
By going large, you may be able to eliminate the need for an amplifier.
